Motion Control and Motor Drives
NI-motion drivers software evaluation
I have download the trial NI motion assistant to try on it. However, it keep coming out this error when i open " Error The NI-Motion driver software is not installed. Please go to ni.com/motion and click the Drivers and Updates link to download the latest version of NI-Motion.:
Btw, is that possible to convert Labview code into C++ code.
Thank you.
(6,581 Views)
Hi William,
as stated in the error message NI Motion Assistant requires the installation of the NI-Motion driver software. In order to start Motion Assistant you need to install NI-Motion and create a simulated motion device in MAX (Measurement and Automation Explorer), that installs with NI-Motion.
If you want to use LabVIEW code in a C++ program, you can compile a DLL from your LabVIEW code and call the functions of this DLL in C++.
Kind regards,
Jochen Klier
(6,576 Views)
