Motion Control and Motor Drives
NI Soft Motion and Bosch Rexroth Linear Actuator
Hi everyone,
I'm trying to control a Bosch Rexroth linear actuator EMC-100-XC-2 with Labview and NI Soft Motion. I have installed the SDI Plug-in from Bosch Rexroth and I have contact with he drive over CoE. When I run the example VI "SDI Plug-in - Bosch Rexroth IndraDrive Example.vi" I get a large overshot on the new target position. It seams that SoftMotion has changed my optimizing parameters, I have set in IndraWorks Ds. Is the SDI Plug-in only made for rotary servodrives? Has someone else used linear actuator from Bosch Rexroth with an different approach?.
Torgeir
(2,137 Views)
Hi twa,
Is this still an issue you're having?
Jack
(2,075 Views)
