Motion Control and Motor Drives
NI-PCI-7332 onboard programming capability
The NI-PCI-7332 datasheet specify this controller board have the onboard programming feature but I can't find any example where it is used with this controller (most examples use the 7340). When I tried to do a simple program (Figure 14-4 of the NI-Motion User Manual) I got error -70022 (Motion:  This command is not supported by this controller or operating system) right after the Begin Program Storage.flx function (OS: Win XP). Is this controller board really compatible with onboard programming?
Ben64
(4,389 Views)
Hi ben64,
If you are looking for examples using the PCI 7332 you can find them in the NI Example Finder. Open LabVIEW and navigate to Help>> Find Examples.
From there, in the lower left hand corner of the example finder, you can add the hardware (PCI 7330) and then check the box to 'Limit results to hardware'. The example finder should now show the examples that are specifically designed for the NI 73xx series cards.
(4,367 Views)
