07-03-2017 07:27 AM
Hello everyone,
I begginner in Labview, I know the bases and some Labview modul like NI-Visa communication.
I try to find motor drive which have an easy communication interface. That means with Labview driver or NI-Visa communication but I don't find suppliers which have motor drive available directly on LabView. So if you know supplier, manufacturer where I can find an easy motor drive communication with Labview please let me know.
Moreover, I did a lot of researchs with some manufacturers like Scheinder Electric and their motors drive have these following interfaces communication (I add some pictures to illustrate the language for the interfacecommunication, coming from the Schneider User Guide).
1-
Communication exemple, refer to 1 :
2-
Communication exemple, refer to 2 :
3-
Communication exemple, refer to 3 :
I don't understand their communications and their User Gudie, I don't know how can I translate that in LabView.
So if you have some recommendations or advices, I'm here to heard you, thank you.
Sincerely,
Aurélien Nicol
(I'm french, if you want to talk in french 😃
07-03-2017 08:13 PM
Hey Aurelien,
Do you know NI SoftMotion? I think you can use NI SoftMotion to implement your application.
07-04-2017 01:27 AM - edited 07-04-2017 01:33 AM
NI SoftMotion is not done only for NI servo motors ?
Because I saw the NI motors and they are not adapted for my devlopment (not enough accurate)
(But I will check that, if NI SoftMotion is usefull for other motor)
07-04-2017 01:33 AM
NI SoftMotion supports SoftMotion Drive Interface (SDI). You can use an NI Real-Time controller and third-party EtherCAT motor drives using NI SoftMotion Drive Interface (SDI).
07-04-2017 01:36 AM
Ok, I will look your advice.
Thank you, I will come back if I have further questions.
10-15-2021 05:05 AM
Hi, I would like to ask you if it was possible to use SoftMotion Drive Interface (SDI) with the stepper from Schneider. I would like to control a motor MDRIVE23 using LabView and I am looking for additional information.
Thank you for your comments.
12-11-2021 07:45 AM
Hi Cam,
The SDI product from NI is now obsolete. If you're looking for a motion control solution with LabVIEW, you can look into GECO Motion:
12-13-2021 04:13 AM
Thank you, I am going to have a look.
regards, Camilo
