I would like to watch an altimeter dial using a camera (monochrome is fine). I would like to track the needle point as it swings and count the number of times it passes "0" cw and ccw around the dial. It will make one complete revolution in a minimum of 4 seconds. This altimeter will have have 10 numbers (0 through 9). Above each of numbers is a bold white line indicating 100 feet. In between the bold lines are 4 thiner and smaller white lines indicating 20 feet.
My Question is: What is the best hardware and software I should use to watch the needle point rotate, determine approx. how far it is from the small and bold white lines, and the approximate climb rate?
Spare no detail... Your help is much appreciated!
