04-05-2018 01:20 AM
Hi Everybody,
Here i need some help to interface TRIO MC403 motion controller with labview but i don't see any drivers related to this product, i need some suggestions on this.
Thank you,
Dinesh
06-16-2018 11:26 AM
Hi
There are no drivers readily available for TRIO controllers in LabVIEW.
The TRIO motion controller setup provides .ocx file. This is accessible in LabVIEW through activex.
06-19-2018 08:54 AM
Hi sir,
Thank you so much for replying me back
Actually i've already found a solution to take control of trio using Activex control in labview but still i was facing some issues in accessing the commands, till now i am able to send the command asynchronously through labview.
In this method i can access only two commands,
1. Send data
2. Get data
In between there is no other command is working, is that any communication issue or any other issues?
. I've attached you a software reference manual with this, tell me if there is any possible solutions.
Dinesh
