Motion Control and Motor Drives
Maxon Motor Control and NI UMI7774
I am using maxon motor control PWM servoamplifier ADS 50/10 for my application.I am currently working on a project that requires me to get the precise position (mesure) with an incremental encoder with 2 channels A and B. I am Using NI Motion, NI UMI-7774,NI PCI 7550, and Labview 10
I try to connect my maxon direct with the Labview Hardware NI UMI 7774 and i don t know how to do this.
anyone have any idea?
(5,849 Views)
can you please give me some more informations about the problems you see with the connection?
Generally you have to at least connect the "Analog Output", the "Ground" and the "Enable" from the NI-7350 with the Maxon ADS 50/10.
You can find an overview about the pins of the NI UMI-7774 here on page 16/17:
http://www.ni.com/pdf/manuals/373359c.pdf
The connector for the Maxon you can find here:
http://www.farnell.com/datasheets/6244.pdf
Please tell me, what informations you are looking for.
Johannes
(5,835 Views)
Thank You for your Answer,
I have the maxon motor control ADS_E50/10 and not ADS 50/10
I resolved the first problem.Thank for your Indication.
The second Proble now is that the motor is not running and i d ont know why.
I have of my maxon motor control ADS_E 50/10 one Error because the green LED(by Ready/Error) blink.
Can you help me and tell me how can i correctly connect my maxon control ADS_E 50/10 and my motor?
Thank You!!!
Best Regards
(5,829 Views)
Have you checked, that the "Enable" ("Active High"/"Active Low" ) matches on all devices?
(5,827 Views)
the enable on all devices of my labview NI UMI 7774 is of "Active High".
(5,825 Views)
