02-23-2012 03:46 PM
I am using MAX 5.0 with a PCI 7342. I need to change some settings for each of the axis controlled by the motion control board, but when I open MAX I see empty settings pages as shown below:
I have tried to reinstall the MAX software; and reinstalling the PCI 7342 device, without any result. I also tried changing to default settings which also does not work. Has anyone seen this before? What do I need to do to get the MAX software to properly recognize the PCI card's settings pages?
Thanks in advance for your help.
Sacha
02-24-2012 02:50 PM
Hi Sacha,
Have you tried Resetting your MAX configuration data? To do this in MAX go to Tools>>Reset Configuration Data.
Are you able to change any of the settings with these motors such as the Trajectory Settings?
Kira T
02-24-2012 06:39 PM
Hi Kira,
That solved our problem, thanks. I was not aware of the option to reset the configuration data- I tried to load the default configuration but that did not work.
Thanks again for your help!
Best,
Sacha
