Motion Control and Motor Drives
LabVIEW Robotics Module Version 2012 Hardware setup error
Hi, I came into the problem of unable to configure my robotics module when using the Hardware setup software, the error code is -2147220308. And there is a call chain :
nisyscfg.lvlib:Uninstall All.vi:1
Install all available SW.vi
Wizard.vi
It should correspond to the error of
Could not contact remote target. Ensure that the system is online
Don't know what that stand for, help.
(2,237 Views)
(2,217 Views)
Thanks for the advice, I solved the problem, it turns out a router will do the job just fine. By connecting my computer and the car to a router(doesn't matter if it's wireless, any router with a DHCP will do), and then reset the ip address of the car, which I set when I didn't get that router. After these, the car is finally recognizable to my computer.
谢谢你的建议,我已经解决了这个问题,原来直接把小车连在电脑上还是不行的,需要一个具有DHCP功能的设备(一般的有线或无线路由器就行),通过把两个设备都连在路由器的LAN端口上,就可以让电脑识别小车了。当然,我还走了一些弯路,因为之前把小车直接连接到电脑上运行Hardware Configuration的时候,虽然一开始能够识别,我还能用电脑给它一个ip地址,但后来的步骤里就会出问题。如果一开始就用电脑给了小车一个ip地址,在换到正确的,使用路由器的方法之前,要先重置小车的ip地址。
(2,146 Views)
