09-10-2014 04:23 PM
Hi ,
i try to use the Kollmorgen driver AKD-P00606 with motor AKM32H
I don t know have to enable the hardware . I try to use WorkBench but only i juste enable the software .
How can i do please to enable the hardware with WorkBench ?
Solved! Go to Solution.
09-11-2014 12:56 PM
You cannot hardware enable the drive from WorkBench. The hardware enable pin is X8/4 and it must be powered in order for the drive to be hardware enabled. See page 134 of the installation guide for more information.
09-11-2014 01:17 PM
Hi Paul ,
i found the problem, i did not connect the X8-3 but only the X8-4 .
but now it run
thank you
07-21-2017 02:22 PM - edited 07-21-2017 02:23 PM
What did you use to power the STO? I have seen in the drawings to connect it to X1/3 or to give 24VDC+. May I ask what you have connected to X8/3 & 4??
