Motion Control and Motor Drives
Jog mode in XPS to reset the positioners.
I am using a Newport M-IMS600CC Linear motion stage along with the XPS Q8 motion controller. How can I use the Jog Mode to reset the Single Axis positioner with the maximum velocity to 0 after it has moved the entire traveling distance?
(5,272 Views)
The products you mentioned are third party and are not supported by National Instruments.  If Newport provided you with you with their own custom VIs, it may be best to contact them about their functions and how to use them.  If there are any issues imorting those VIs into LabVIEW we will be able to further assist you.
Isaac S.
(5,259 Views)
