Motion Control and Motor Drives
Is it possible to perfectly synchronize 7 axes using 2 motion controllers 7344?
Is it possible to perfectly synchronize seven axes with blend move using two distinct motion controllers 7344?
(2,768 Views)
Check out the following Knowledge Base, which offers two main suggestions for simultaneously starting motion across multiple controllers. To synchronize the start and stop on all axes, you would have to calculate the appropriate move constraints for each axis that would bring it to the end of travel with the others, and then use one the methods described in the Knowledge Base.
Knowledge Base 19KCOC0W: How to Synchronize Two FlexMotion Boards to Start Simultaneously
I hope this helps!
Dawna P.
(2,768 Views)
