06-07-2018 09:13 AM
Hi everyone,
I am using CRIO-9049 and Yaskawa Sigma-7 motors and EtherCAT drives.
Now, I can set the motor in velocity mode and torque mode with property nodes, and the motors run well in both control modes.
But I can't stop the motors using Stop function. How should I achieve it?
By the way, if I want to stop the motors by deceleration, how can i load the rate of deceleration?
06-10-2018 01:56 PM
06-18-2018 10:14 AM
I don't know whether Yaskawa motors support this, but in SoftMotion there is an option for specifying a behaviour once a software limit has been passed (for Kollmorgen motors). You can access this "Axis Configuration" window by right-klicking the axis in the project view and selecting "Properties".
Some motor drives also use a "Safe torque off" option, based on an external high/low digital line directly to the motor drive.
Anyway, be careful 🙂
Best regards
Lysandros
