03-09-2006 01:57 AM
03-09-2006 02:59 AM
Connect the encoder to the UMI. Drag the read position VI into the block diagram and put it in a while loop. Give the board ID as shown in max. Provide the axis to which the encoder i connected. Put an indicator to diaply the counts.Now run the VI and rotate the encoder to see the counts.
Giridhar Rajan
Automation Engineer, Design
Cruiser Controls
Mumbai, India
03-12-2006 09:55 PM
03-12-2006 10:59 PM
Please find the examples in LabVIEW folder. The VI that you want is already demonstrated there. I do not have motion driver installed, so can give example, sorry.
Giridhar Rajan
Cruiser Controls
Mumbai, India
03-14-2006 01:28 AM
Hey bkk,
You can find all the motion examples in the following folder: C:\Program Files\National Instruments\LabVIEW x.x \examples\Motion\FlexMotion. You can find these examples if you have the NI-Motion driver installed. Also, you can find examples in the NI Example Finder if you do a search and Browse by directory structure - in the Motion folder.
DJ L.
12-15-2006 09:39 AM
I also have to define a erchitecture using a PXI 7342
Can you describe me your hardware architecture
Regards
Thibaut
