Motion Control and Motor Drives
How to control the velocity of the EC motor with the digital 4-Q-EC Amplifier?
i'm begginer on the field, can someone give me some tips of what I need to do to control the velocity of this motor?
I have the:
1 - EC 45 Ø45 mm, brushless, 250 Watt, with Hall sensors.
https://www.maxonmotor.com/medias/sys_master/root/8830474944542/2018EN-215.pdf
2 - DEC 70/10, digital 4-Q-EC Amplifier 70 V / 10 A, speed control, current control,
https://www.maxonmotor.com/medias/sys_master/root/8830256218142/306089-DEC-70-10-Operating-Instructi...
3 -NI USD DAQ.
From the catalog of the digital 4-Q-EC, it seems I need to make the Minimum External Wiring for velocity control (point 3.2).
As seem on image 1 and 2, I plugged the wires, now I think I have to use the wires 13 and 14 to set the value. Do I put the vout from NI in one of them?
Does it need at least 10v to turn on the system? and the NI provides the maximum of 5v? What to do about that?
Thanks.
(2,254 Views)
Hello!
How are you?
Are you still working on this? Did you manage to make it work?
Could you help me to better understand your project? Are you trying to read some information using DAQ? What is it that you need to read? Do you need to work with a closed loop?
Best Regards,
Lígia T. Ferreira
Technical Support Engineer
National Instruments Brazil
(2,069 Views)
