06-10-2008 06:26 AM
06-10-2008 08:20 AM
06-10-2008 09:49 AM
06-10-2008 09:58 AM
06-10-2008 10:55 AM
06-11-2008 03:16 AM
12-08-2008 05:24 AM
I have the same problem with a Plasma cutter. We have a 7344 card with two servo's. Blending line to arc, and line to line works fine. Blending multiple arc moves gives motor jumps, and the blending does not occur. Our system also has M and G-code input. I see three possible solutions: (1) contouring mode: this requires quite some programming converting our G- codes into a contouring pattern including maintaining constant cutting speed, it looks to me that the biggest disadvantage is the deviation from our software architecture, and losing the possibility for "infinite" cutting length. (2) NI comes with the major bug fix, this is the option I hope for (3) we switch to another motion card manufacturer wich does not have this problem, this is the option I fear in case NI can't deliver a bugfix.
Does this bug also occur in older versions of the NI firmware? Maybe switching to NI-motion 6.xx could help?
12-08-2008 06:45 AM - edited 12-08-2008 06:47 AM
Dre-motion,
I'm sorry that this issue is causing trouble to you. As much as I know, R&D is working on this issue, but I currently can't provide exact information about the release date of a driver version that contains the fix. I'm in contact with R&D again and I should be able to provide better information soon.
The issue was also present in older firmware versions, so downgrading is not a resolution. Could you please provide some information about your deadlines?
Thanks and kind regards,
Jochen
12-11-2008 03:53 AM
Hi Jochen,
The plasma cutter is about finished, except for the arc-blend bug (and some minor post processor bugs).
We planned to ship this machine at the end of Januari 2009.
André.
12-16-2008 01:51 AM
Hi André,
I have received some information from R&D. The issue was analyzed thoroughly, but apparently the issue is deep-rooted in the architecture of the 73xx firmware and there is no short- or mid-term solution in sight.
Besides the alternative options that you have mentioned, another idea comes to my mind: The 7350 provide a low-pass filter for the control output. For servos the velocity glitch that you see could be damped significantly by adjusting the Cutoff Frequency appropriately. I know, that you are using a 7344 and not a 735x, but if your local NI branch could send you a 735x for testing you could give it a try.
I don't think, that this could fix the issue completely, but it could reduce it to an acceptable level without redesigning your code.
Jochen
