Gain tuning panel not present on NI 9514 axis (EtherCAT)
I'm configuring a new axis with the NI 9514 servo drive interface (analog). The c-series module is mounted on an EtherCAT chassis 9144. Once I bound the axis to the module, I can access "Interactive Test Panel" and I can also access property to change the PID gain BUT "Gain Tuning panel" is now showing when right click on the axis.
If 9514 is mounted on a cRIO chassis, I can access that menu.
Is it a bug? why NI didn't add that option, is there work around or VI I can use to tune my motor.
Thank you.
(2,289 Views)
err: "Gain Tuning panel" is NOT showing when right click on the axis.
Thank you.
(2,269 Views)
Hi.
What is your complete setup?
Regards
(2,258 Views)
Setup is a CVS 1458RT and a EtherCAT chassis 9144, the module 9514 is on the EtherCAT chassis.
(2,255 Views)
I just found an example, I will let you know if that work for a work-around :
\National Instruments\LabVIEW 2016\examples\motion\ConfigurationAPI\Custom Tuning
(2,246 Views)
This last example can be a work-around for previous version but unfortunately not for the version 2018. The function "write position setpoint" (no constraint profile) is not allowed in version 2018 using a NI 951x module which is not a good decision in my opinion.
This function is really useful for PID Tuning but even more important and useful for motion tracking.
(2,227 Views)
