Encoder Feedback with a Servo Motor
I want to use Encoder oder Position feedback with my servo motor in MAX or VIs. How do I do it?
(6,296 Views)
Accepted by fregue
Hi Fregue
what LV Version and HW is in use?
I have seen in your other posts you are using a  NI UMI-7774,NI PCI 7550, and Labview 2010 is this correct?
If the encoder is connected to the UMI you should be able to see the signals in MAX.
You can select the closed loop step
then the encoder is used to control the positon.
Please check if the microsteps from the motion devcive and the encoder steps per revolution are correct
Then you should able to use the encoder.
You can also use the MAX to check if the encoder is connected correct in the interactive tab.
I hope this helps.
best regards
Alexander
(6,287 Views)
