Motion Control and Motor Drives
ESP300 and MFA-PPD translation stage
Hi all,
I'm trying to set the resolution for the MFA-PPD and Newport said the motor should automatically recognize the stage because it has a built in EEPROM.
It does recognize it but the resolution (after querying xxSU? or through the utility) tells me it is ~0.000484 mm. When I move the motor manually through the front panel of the ESP300, I can move it in steps of 0.00000757 mm (as the manual says). I'm worried that all the other settings are not correct so I called and asked Newport if they can give me a text file that can initialize the stages with its parameters. They said they don't have it and it should be able to recognize through the ESP300 automatically.
I usually generate the parameters using the wizard but the motor MFA-PP series do not show at all. I was wondering if anyone had a similar problem and was able to generate the parameters. Any help is appreciated and thanks in advance.
-Sam
(5,505 Views)
I'm not familiar with that hardware. I assume that the stage is connected over serial, are you getting strange responses from any other queries?
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(5,492 Views)
thanks for your reply. i actually got it figured out by calling newport. it is actually 1/64th of 0.000484.
(5,470 Views)
