Dynamixel motor wheel mode velocity control cw / ccw
Hi~
I use LabVIEW to control dynamixel AX-12 motor, and use velocity command to motor
How can I change from CW to CCW in LabVIEW?
(2,880 Views)
Hi Newone,
I think it would get more feedback if you post this issue here.
https://github.com/ROBOTIS-GIT/DynamixelSDK/issues/118
I just do a quick search for model AX12
http://www.trossenrobotics.com/images/productdownloads/AX-12(English).pdf
page.19 BIT10 is for the direction.
https://github.com/ROBOTIS-GIT/DynamixelSDK/blob/master/c/example/protocol2.0/sync_read_write/sync_r...
good luck
(2,853 Views)
Thanks schwarmcyc,
I just find how to control
if 100 is cw turn, then 100+1023=1123 is same speed but ccw turn for motor
(2,839 Views)
