03-05-2012 08:11 PM
I am using the Getting Started with NI 951x C Series Modules and LabVIEW tutorial and I can't seem to get it to work. I followed it step by step and when I clicked execute on the front panel, I got the following error. Error code: 70028
Straight-Line Move when Setting Position[] on Test Section.<ERR>
The resource is not large enough to perform the specified operation.
<b>Complete call chain:</b>
nimc.getLastErrorOnInterface.vi
nimc.fb.straightLineMove.startStraightLineMove.coordinate.modeAbsolute.0.vi:1
Straight line move 2.vi
All I did was create a 3 axis coordinate space and the tutorial calls for two. I tried removing one axis and only using two but that didn't work. My block diagram looks the same as the one in the example except I seem to only have ONE coordinate in my system (notice the bottom left wire connected to position[] only has one coordinate box instead of two like the example). I've tried starting over and re-creating the coordinate axis and the VI with the same result. Am I missing something? It seems as though my coordinate system is showing up as 1x0 array instead of a 1x3 array or something?
I tried rebooting the cRIO and starting an entirely new project, basically starting from step 1 excluding the installing of software on the cRIO. Please let me know if you have any advice or have had any of the same problems. Thanks
03-06-2012 05:14 PM
