10-19-2018 06:51 PM
Is it possible to control more than 4 brushless DC motors with a myRIO controller? I have 2 Motor Adapters from Digilent and a sabertooth motor controller.
I have a project that requires around 8 BLDC motors.
Is it possible with this set up? if not, what is the maximum number of motors that I can control with this? I believe that it is 6, but I am not 100% sure.
Thank you in advance!
10-22-2018 09:27 AM
What kind of input needs your Motor Adapter from Digilent?
10-22-2018 01:19 PM
I’m not quite sure what you’re asking but here is the link to the digilent adapter that I have (2 of them):
https://store.digilentinc.com/motor-adapter-for-ni-myrio/
i need to be able to control the direction and speed of the motors.
Thank you!
10-23-2018 04:10 PM
From that webpage it looks like you can control 2 DC motors throught the MXP connection of the MyRIO. If you have 2 MXP ports you could probably connect 2 of these boards which would give you control over 4 motors.
-TyVo
