Motion Control and Motor Drives
Control Step Motor in LabVIEW via Step Motor Driver
No. What are you talking about?
Message 21 of 30
(3,746 Views)
I don't know the details of that model, but RS-485 is used for multidropping devices, and hence any commands sent need to have an address associated with them so that a particular device knows that it should act on those commands.
Message 22 of 30
(3,745 Views)
Ah. Gotcha. Well through the manufacturer's included software, i have assigned this motor an address of "1."  However, no where in my program do I specify a particular address. How would I go about doing this? Why does the motor still follow the programs commands even though i'm not calling it by name?
Message 23 of 30
(3,742 Views)
Are you saying that you can send commands and it responds, and that you can request information and it responds, but it just won't give you the encoder position?  What command are you using?
Message 24 of 30
(3,733 Views)
Has there been a resolution to this? I also have a STM-23S-3RE and I have set the drive to SCL mode, but can not send/recieve basic commands.
Doug Ferguson
Message 25 of 30
(3,378 Views)
Brian,
Hello, I realize this conversation was from 2006, but if you are still following this forum, I'd love to ask you a few questions about the VI you designed to control the Applied Motion stepper motors.  I'm inexperienced with LabVIEW and I'd like to explore some of your reasoning in making the VI.  I've got a similar setup and am stuck.  If we could talk over the phone even, that would be great.  Let me know, otherwise thanks for your time and consideration.
-Ryan
Message 26 of 30
(3,046 Views)
Ryan-
I may not have any good reasoning for doing things the way I did.  I haven't used the Applied stuff for a couple of years.  I could give you a call sometime in the evening.  Send me your phone number to bbeal66(at)yahoo.com.
Message 27 of 30
(3,042 Views)
Hi Brian,
It looks like this discussion keeps getting resurrected...  Probably because it's so useful.
I get the following error code: -1073807246 when I run the .vi file.  This is not quite the NI VISA error code that you or Irene mentioned earlier in this thread, but I will start by checking my NI VISA installation.  Any ideas on what else could be going on?   Using Applied Motion software, I am able to command the hardware just fine, I am currently trying to command it from Labview though.
Thanks in advance!
Frank
Message 28 of 30
(2,439 Views)
Frank-
That usually means that the com port is being used by some other program.  Are you closing out the Applied Motion software before you try it in LabVIEW?
Brian
Message 29 of 30
(2,436 Views)
Right on!  Thank you very much.
-Frank
Message 30 of 30
(2,434 Views)
