Motion Control and Motor Drives
Can You Set the Stepper Output Mode Differently for Multiple Axes?
(6,283 Views)
I'm using the Measurement and Automation Explorer (MAX) to setup my Motion board. If I try to set the "Stepper Output Mode" to be "Step and Direction" for one axis and "Clockwise/Counterclockwise" for another axis, both axes will change modes to "Clockwise/Counterclockwise". Why is this?
Solution: ValueMotion software configures the step outputs for all four axes to be the same. You cannot have a different "Stepper Output Mode" for different axes using ValueMotion. This is documented in the Online Help for the "Set Step Output Mode VI" in LabVIEW.
(6,283 Views)
