02-19-2009 01:35 AM
02-19-2009 03:54 AM
Hello Kurt,
the breakpoint feature of the PCI-7332 requires software rearming and there is no way around that. Fast onboard rearming is only available with NI 7350 boards, like the PCI-7352. NI 7350 board provide a maximum periodic breakpoint rate of 4 MHz per axis. You could ask your local NI branch for a hardware upgrade.
The other option is routing the encoder signal to the RTSI, but this might have some drawbacks (e. g. micro-oscillations on the encoder causing unsolicited DAQ readings).
I hope that helps,
Jochen Klier
02-19-2009 04:25 PM
Thanks Jochen
Unfortunately I dont think out client will allow us to go to the 7350, so I think the way to go is to clock off the encoder. Perhaps another way would be to clock off the stepper motor, that way we wont get jitter.
02-20-2009 01:57 AM
Kurt,
using the stepper output signal seems to be a good option then. Cabling is a bit more complicated, as this signal can't be routed to the RTSI lines, but it's a better choice in terms of synchronisation quality.
Jochen
