Measurement Studio for VC++
setting CAN FD baud rate in c using c driver
I need to set the baud rate to 2Megbit for CAN FD.  The manual and the example are not working using the set properties for Session
(5,224 Views)
Hi mikeatbosch,
We may need more details on you setup to understand the issue better. Which examples are you using? Also, what is the behavior you are seeing in your program? Are you getting any errors? Which hardware and software are using?
 Also, you may find some help in the Automotive and Embedded Networks forum.
David C
(5,184 Views)
