Measurement Studio for VC++
sbRIO communication failure
Hi, I have a sbRIO 9631, labview 2012, RT and FPGA, I connect it to my PC windows 11. When I am compiling shows an error "this host does not have the appropriate Microsoft Visual C++", I do correctly "to install the required package run", and it says "Microsoft visual C++ 2008 has been successfully installed", and the problem is not solved,  Please would you like to tell me what I must do?
thank you so much,
(420 Views)
Have you tried using probably lower OS version like Windows 10 or Windows 7 and see if the issue occurs?
(299 Views)
