Measurement Studio for VC++
What is the ID of an Attribute?
I am trying to make a simple get call niRFSA_GetAttributeViString. Where can I find the ID of an Attribute?
I am trying to make a call to the NIRFSA_ATTR_SERIAL_NUMBER but this attribute is not working. I receive the error : -1074135028
IVI: (Hex 0xBFFA000C) Attribute ID not recognized
(3,480 Views)
Hi!
Have you checked this help page of the valid attributes? I don't think Serial Number is a valid attribute for this function. You may be interested in  this function instead.
(3,382 Views)
Hi, Thank you for your reply.
I have been using the attributes found here under the
"Attributes"->"Device Characteristics"->"NIRFSA_ATTR_SERIAL_NUMBER"
My hardware is supported by the reference here. However it may be because I am using a simulated one in MAX? The given C examples work for NI-SCOPE as far as compiling and returning standard values..But I do not see any examples that run the functions with ViAttr type. Any Thoughts?
(3,374 Views)
Have you tried the function call in the second link I posted above? If you are attempting to return the serial number, you can do so using that call.
(3,278 Views)
 No, the function I used worked fine. The attribute is treated as a MACRO not a string literal as I originally though
(3,257 Views)
