Measurement Studio for VC++
Update NiGraph from thread
I am using MSVC++ 6.0 and am utilizing a homegrown timer to update my status on the screen. This timer utilized a worker thread and calls a HandleTimer method in my dialog class to update the status. I can update all my MSVC++ widgets okay but when I go to update the NiGraph m_Graph via a m_Graph.ChartXY(x,y) it blows up. I can make the same call, m_Graph.Chart(x,y), via a button call back and it works fine. Yes, the values are doubles and they are initialized okay. Has anybody else run into this issue?
jim
(3,164 Views)
This is probably happening because you haven't called CoInitialize in the worker thread. You can confirm this by catching the exception and displaying it via CException::ReportError. If this is the case, you can fix the issue by calling ::CoInitialize(NULL) at the beginning of the worker thread and calling ::CoUninitialize() before the thread exits.
(3,154 Views)
