Measurement Studio for VC++
Trouble auto-starting a NIDAQ app as a service
I built a NIDAQ app using Visual C++ 6.0 as a WinNT/Win2K service. The service can be manually started and stopped on all test systems without a problem. When auto-starting the service, the results are inconsistent. On some machines it starts, on others it fails. When it fails, the error code indicates it failed to load a DLL. By process of elimination, it appears that the NIDAQ DLL's are the problem (i.e., the service auto-starts when the NIDAQ code is commented out). This problem happens with NIDAQ 6.9.2 but not NIDAQ 6.7. Are there some service dependencies that need to be specified?
(3,182 Views)
At first glance, the error you are seeing reminds me of the problem described in the following knowledgebase:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/38afa6f57a0edc1586256ab2005cc81d?OpenDocument
where a DLL that NI-DAQ depends on is not able to load due to a base address conflict with a Microsoft DLL.
There's a patch included in the KB that might help you fix this problem, if it's even related.
If this doesn't help, I would suggest you post the same question to the DAQ forum.
Azucena
(3,182 Views)
HEllo;
There is a KnowledgeBase that talks about that sort of error.
If you go to www.ni.com and type +exception +error in the search field. The fourth result is the one that I'm referring to.
Hope this helps.
Filipe A.
(3,182 Views)
