02-21-2018 09:14 AM
So I am new to daqmxBase and daq .
What I want to achieve:
- To simply record voltage from the analog input channel of my daq device ( NI DAQ 6008 )
- Use a C program to do the same and compile it using clang or gcc at the "terminal" of my macos
Software Details:
- macos High Sierra 10.13.3
- downloaded the nidaqmxBase 15 software for macos
C Program that I am trying to compile
http://www.ni.com/tutorial/5409/en/
- this code basically includes "NIDAQmx.h" which gives off an error so I changed it to "nidaqmxbase/NIDAQmxBase.h"
- also I changed all DAQmx functions to DAQmxBase functions
THE ERROR
- The C program simply would not compile and give the following error:
Undefined symbols for architecture x86_64:
"_DAQmxBaseCfgSampClkTiming", referenced from:
_main in daqmirror-da73d6.o
"_DAQmxBaseClearTask", referenced from:
"_DAQmxBaseCreateAIVoltageChan", referenced from:
"_DAQmxBaseCreateTask", referenced from:
"_DAQmxBaseGetExtendedErrorInfo", referenced from:
"_DAQmxBaseReadAnalogF64", referenced from:
"_DAQmxBaseStartTask", referenced from:
"_DAQmxBaseStopTask", referenced from:
ld: symbol(s) not found for architecture x86_64
I am new to C as well as the daqmxBase library so could you please suggest at to what is causing this error?
The code was directly copy pasted from the ni website and still it fails to compile.
Also, none of the examples compile . They too give the same error.
Solved! Go to Solution.
02-21-2018 07:02 PM
When you install the C API for NI-DAQmx Base, it also installs C examples here: /Applications/National Instruments/NI-DAQmx Base/examples
For example, to build the analog input examples, do:
$ cd /Applications/National Instruments/NI-DAQmx Base/examples/ai
$ make
$ ./acquireNScans
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
02-22-2018 12:03 AM
Thanks Joe ! I did exactly as you insisted.
The 'make' compiler did manage to compile all .c examples in the AI folder.
Then tried running each one of them one by one but it just fails to run!
It gives the following runtime error:
2018-02-22 11:25:18.628 acquireNScans[5455:826073] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'nextEventMatchingMask should only be called from the Main Thread!'
*** First throw call stack:
0 CoreFoundation 0x00007fff47021fcb __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fff6dcc3c76 objc_exception_throw + 48
2 AppKit 0x00007fff44d14faf -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 4167
3 LabVIEW 15.0 Runtime 0x000000010f7c1b91 WEventAvail + 833
4 LabVIEW 15.0 Runtime 0x000000010f55ba7e Exec + 1246
5 LabVIEW 15.0 Runtime 0x000000010f550f8a _Z16DoBackgroundExeci + 202
6 LabVIEW 15.0 Runtime 0x000000010f6e8e6a _ZN12BGAppTask_MG11HandleTasksEi + 138
7 LabVIEW 15.0 Runtime 0x000000010f6d9fe3 _ZN15BGAppTask_MacUI21CheckAndHandleBGEventEv + 51
8 LabVIEW 15.0 Runtime 0x000000010f6dcc6d _Z33BGAppTasksRunLoopObserverCallbackP19__CFRunLoopObservermPv + 301
9 CoreFoundation 0x00007fff46fba127 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
10 CoreFoundation 0x00007fff46fba04f __CFRunLoopDoObservers + 527
11 CoreFoundation 0x00007fff46f9c6c3 __CFRunLoopRun + 1267
12 CoreFoundation 0x00007fff46f9bf43 CFRunLoopRunSpecific + 483
13 LabVIEW 15.0 Runtime 0x000000010f6d8387 _ZN19MainLoop_MacCocoaUI3RunEv + 279
14 LabVIEW 15.0 Runtime 0x000000010ea43a46 _Z6MGMainiPKPKc + 294
15 LabVIEW 15.0 Runtime 0x000000010ea4450d _Z11SysUIThreadPv + 13
16 LabVIEW 15.0 Runtime 0x000000010f83803e _Z15ThreadCoverProcPv + 94
17 libsystem_pthread.dylib 0x00007fff6eb3e6c1 _pthread_body + 340
18 libsystem_pthread.dylib 0x00007fff6eb3e56d _pthread_body + 0
19 libsystem_pthread.dylib 0x00007fff6eb3dc5d thread_start + 13
libc++abi.dylib: terminating with uncaught exception of type NSException
Abort trap: 6
The thing is I program mainly in Java , and i need to acquire I/O control over the NI Daq 6008 , therefore I am trying to wrap my head around the C programs so that i could write my own basic acquire signal programs and then use it in Java
I just need a proof of concept: The C program should read "9V" from the battery connected to my daq 6008 device.Once i can read and then output an analog signal to the daq device using a basic C program half of my work is already done!
02-22-2018 12:18 AM
Another thread with the same error:
02-22-2018 10:24 AM
Hmm... yes, this looks like a hard stop for you right now 😞
Until the internal implementation is updated to match the new OS X behavior, the C API cannot be used. I'll bring this to the attention of that team.
Joe Friedchicken
02-22-2018 11:35 AM
yes Thanks!
Looks like this is the end of road as of now..
Lets hope NI mends it soon..
02-22-2018 11:57 AM
@swapcool wrote:
Lets hope NI mends it soon...
The team is aware of this crash, and the lower level bug from the internal layer has been fixed. The next steps are to include those updates in the driver. I don't know their schedule, but it seems "soon" is reasonable for some values of "soon" 🙂
Joe Friedchicken
