Measurement Studio for VC++
ReadDigital32 writing out of bounds of array and freezing computer?
Hello all, I am a graduate student will little programming experience trying to modify our lab's code to use a new detector which interfaces to the computer with a NI PCI-6534 card.  The code is written in Borland C++ builder 6 and uses the ANSI C library support provided with the NIDAQmx drivers.
I have been able to get data, but have run into problems when trying to run experiments and retrieve many scans.  After taking so many scans, the computer will freeze up completely, as in you must hold down the power button for a hard reset.  How many scans before this occurs is tied to how many accumulations are requested, higher accumulations will freeze the computer in fewer measurements.  It seems to be somehow related to the NIDAQmx ReadDigital32 function writing outside of the allocated bounds of the buffer array, as the computer only freezes when I include this step while executing the program, and purposefully making the buffer much larger, say 100x, only delays the freezing.  I
This is the our code that reads the data, I only copied enough of the GetScanData() function to show where it puts the data from the GetRawData() function:
bool MultiChDetector::getRawData(uInt32 *dbuffer, int nRawScans) {
   if (nRawScans>5000)   {
   last_error = "Bad number of accumulations" ;
   return false;
    MeasurementTask acq_task;
    //One 32bit channel with 16 bit upper and lower words
    DAQ_ERR( DAQmxCreateDIChan(acq_task.h(), DAQ_DEVICE"/port0_32", "Port32", DAQmx_Val_ChanForAllLines) );
    DAQ_ERR( DAQmxCfgSampClkTiming(
        acq_task.h(),
        NULL, //internal clock
        10e6, //10 MHz
        DAQmx_Val_Rising,
        DAQmx_Val_FiniteSamps, //DAQmx_Val_ContSamps
        MCHD_CH_AMT*nRawScans) );
    DAQ_ERR( DAQmxCfgBurstHandshakingTimingExportClock(
        acq_task.h(),
        MCHD_CH_AMT*nRawScans,
        10e6, //10 MHz
        "/"DAQ_DEVICE"/PFI4",
        DAQmx_Val_ActiveHigh, //the polarity for exported sample clock: active high or active low
        DAQmx_Val_High, //whether the task pauses while the signal is high or low
        DAQmx_Val_ActiveHigh) ); //the polarity for the Ready for Transfer event (System Ready)
    double timeout_sec = 10.0 + nRawScans/1e3; //sec timeout, 1e3 = 1 kHz
    bool interactive_wait = false;
 if(interactive_wait) {
    DAQ_ERR( DAQmxStartTask(acq_task.h()) );   // don't forget to Stop Task
    int time0=GetTickCount();
    unsigned long isDone=false;
    do {
        Application->ProcessMessages();
        DAQ_ERR( DAQmxIsTaskDone(acq_task.h(), &isDone) );
        if(isDone) {
            break;
        if( (GetTickCount()-time0)> int(1000*timeout_sec) ) {
            Application->MessageBox("Error", "Multi-channel data not ready in time", MB_OK);
            break;
    while(!isDone);
    int32 nRead = 0;
   DAQ_ERR( DAQmxReadDigitalU32(
        acq_task.h(),
        timeout_sec,
        DAQmx_Val_GroupByChannel,
        dbuffer,
        &nRead,
        NULL) );
    if (nRead != MCHD_CH_AMT*nRawScans) {
        last_error = "Less amount of data was read";
        return false;
        DAQ_ERR( DAQmxStopTask(acq_task.h()) );
    /*thr_buffer = buffer;
    thr_counter = nRawScans*MCHD_CH_AMT;
    thr_request_scan = true;
    while (thr_counter);
    return true;
bool MultiChDetector::getScanDataS(float *destBuffer, ScanType scanType, bool subtractBackground, bool divideReference) {
    bool requestOK;
    bool* bad_points;
    bad_points = new bool[MCHD_CH_AMT];
       int het_extra_pts = 0;
    if (scanType==SetPhase12){
    het_extra_pts=3;
    double *raw_data = (double *)calloc(MCHD_CH_AMT, sizeof(double));
    double *norm_data = (double *)calloc(64, sizeof(double));
    uInt16 *buffer = (uInt16 *)calloc(MCHD_CH_AMT*(nScans+het_extra_pts), sizeof(uInt16));
    uInt32 *dual_buffer = (uInt32*)calloc(MCHD_CH_AMT*(nScans+het_extra_pts+200), sizeof(uInt32));  //Furman
    //uInt16 *externalch = (uInt16*)calloc(16), sizeof(uInt16));
    try {
        if (!getRawData(dual_buffer, nScans+het_extra_pts)) {
            return false;
    for(int d=0; d<nScans*MCHD_CH_AMT; d+=128){ //Discarding extra data from 16 external inputs and unused channels (up to 256) and skip first channel
        for (int a=0; a<64; a+=16){             //Separating the upper and lower words of the 32 bit samples dbuffer[0]->buffer[16,0], etc.
                for (int b=0; b<8; b++){        //FIFO reads out even then odd channels 0246...1357
                        buffer[(2*a)+(2*b)+d]=(uInt16)dual_buffer[a+b+(d+1)];
                        buffer[(2*a+16)+(2*b)+d]=(uInt16)(dual_buffer[a+b+(d+1)]>>16);
                        buffer[(2*a)+(2*b+1)+d]=(uInt16)dual_buffer[a+(b+8)+(d+1)];
                        buffer[(2*a+16)+(2*b+1)+d]=(uInt16)(dual_buffer[a+(b+8)+(d+1)]>>16);
if (scanType == AccumulationScan) {
            for (int s = 0; s < nScans; ++s) {
                for (int c = 0; c < MCHD_CH_AMT; ++c) {
                    raw_data[c] += buffer[MCHD_CH_AMT*s + c];
                raw_data[c] /= nScans;
                raw_data[c] *= MCHD_COEFF;
 __finally {
        free(raw_data);
        free(norm_data);
        free(buffer);
        free(dual_buffer);
        delete[] bad_points;
    return true;
This is the system information form NI MAX:
Operating System(OS)                     Windows 7 Professional
OS Version                               6.01.7601
OS Info                                  Service Pack 1
Processor                                Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz / x86 Family 6 Model 60 Stepping 3 / GenuineIntel / 3299 MHz
Number of Processors                     4
Physical Memory                          3.20 GB of RAM
Drive C:\                                108 GB of 232 GB free
National Instruments Software:           Version:
CVI Run-Time                             8.1.1.361
NI-DAQmx Device Driver                   15.5.1f0
NI-DAQmx ADE Support                     15.5.1
NI-DAQmx MAX Configuration               15.5.1
NI I/O Trace                             15.0.0f0
IVI Compliance Package                   4.0
LabVIEW Run-Time 2012 SP1 f5             12.0.1
Measurement & Automation Explorer        15.3.0f0
Measurement Studio                       Visual Studio 2005 Support - See individual versions below.
     DotNET
          Common                         8.7.20.131
Measurement Studio                       Visual Studio 2010 Support - See individual versions below.
     DotNET
          Common                         15.1.40.49152
          Common (64-bit)                15.1.40.49152
NI-USI                                   1.0.2
NI PXI Platform Services Configuration   15.0.0f1
NI PXI Platform Services Runtime         15.0.0f1
NI-PAL Software                          15.1.0
LabVIEW SignalExpress                    3.5
NI System Configuration                  15.3.0f0
NI-VISA                                  15.0.1
NI-VISA Runtime                          15.0.1
LabVIEW Run-Time 2014 SP1 f3             14.0.1
LabVIEW Run-Time 8.0.1                   8.0.1
LabVIEW Run-Time 8.2.1                   8.2.1
LabVIEW Run-Time 8.5.1                   8.5.1
LabVIEW Run-Time 8.6.1                   8.6.1
LabVIEW Run-Time 2009                    9.0.0
Message 1 of 1
(2,175 Views)
