12-05-2005 10:07 PM
12-07-2005 10:18 AM
12-07-2005 09:27 PM
Thanks a lot! Error with DAQmxCreateAIVoltageChan is now solved, but I have another problem now.
DAQmxStartTask (the third function in the sample code) fails this time, the error message is: "Floating Point division by zero".
Detail error message (BC++B 6.0): Project USB6008.exe raised exception class EZeroDivide with message "Floating point division by zero". Process stopped. Use Step or Run to continue.
Can anybody tell me what is wrong? THanks!
12-08-2005 11:31 AM
12-14-2005 09:29 PM
05-25-2012 08:30 AM
Try using the following as an example. Your device and connection info will change depending upon where you have your inputs connected.
Tim
