11-22-2011 12:45 PM
Hello.
Where can I find API function reference for NI USB-6211?
Thank you
alanbor
11-24-2011 11:37 AM
Hello alanbor,
I am not sure I understood your question. You would like drivers to interface with NI-usb 6211?
11-24-2011 03:03 PM
Hello A.V.
Not exactly drivers. I'm searching for a way my programm could interact with a NI USB-6211 device.
I suppose there should be a C-language API library shipped with it.
Let me explain it further. I need a standalone waveform function generator and now I'm searching for a suitable device.
It should be controllable from my program (waveform parameters configuration, start/stop), but be able to run on its own after being started.
It is also important for me to have an access to internal clock of the device to be able to synchronyze it with host PC.
I could not find answers in the users manual and I hope API function reference will help me.
alanbor.
12-12-2011 07:59 AM
Hello alanbor,
Perhaps what you mean is the C API library ? if yes, you can take a look at this link
12-12-2011 11:29 AM
Dear kusg.
Yes! The C API library is exactly what I am looking for!
Thank you for the link, now I know that it exists....
I have not yet bought the device itself since I'd like first to have a look at its API to estimate its capabilities and then decide if it is worth buying it or not. So I don't have anything installed on my PC. Where can I find and download the C API documentation and examples without buying the device?
alanbor.
12-13-2011 02:53 AM
Perhaps you can try to download from the latest NI-DAQmx drivers here. I guess you may need to understand the examples, to test its API..
12-15-2011 04:44 PM
Thanks kusg.
To elaborate on what Kusg posted, the NI-DAQmx driver contains the various APIs as well as the driver itself. When installing the driver, make sure to select the C API support component from the customer install dialog.
