08-30-2013 05:37 PM
Hello, I have a Basler Camera Link-compatible camera and they use the NI PCIe-1433 Camera Link frame grabber as the image acquisition device.
Right now, I want to develop some applications on that camera and need to do programming on the NI PCIe-1433 by VC++.
So I want to know where I can find the software development kit for the NI PCIe-1433. For example, I can control the camera to grab the image by using the different functions(such as imgGrab(), or somthing like that ) from that software development kit.If there are some sample code that would be better.
09-03-2013 08:58 AM
Hi Wrsbj,
The IMAQ functions that you mentioned are contained in the IMAQ driver, which is used to acquire from Camera Link frame grabbers. I would also check the compatibility chart, to make sure that you get the version you need. As for example programs, you can take a look at this KnowledgeBase article concerning building and running the IMAQ examples in VC++.
04-07-2017 08:41 PM
Thank you for your tips. While I can not access the " this KnowledgeBase "
In the webside "http://digital.ni.com/public.nsf/allkb/3139EBE28D28CFD6862567C500093C27?OpenDocument"
It tells me that "
Error
You are not authorized to view this document
So I cannot get the examples about the C++ development kit .
Can you help me to access the sources, or give me the examples .
Best Wishes for you !
MailBox: defender2009@163.com
