Measurement Studio for VC++
NI-DAQmx Devices disappeared in MAX Configuration
From time to time, our application will hang (black screen), the reason of this black screen is the NI-DAQmx Devices disappeared under Devices and Interfaces.
When I clicked on the + sign to expand the tree, any of item under My System
- My System
     Data Neighborhood
     Scales
     Software
     VI Logger Tasks
Message 1 of 12
(7,600 Views)
It sounds like something has become corrupt in your DAQ driver. The latest version of DAQmx is 8.0.1. If you have an older version, then I recommend upgrading to the new driver. If you currently have this version, then you can repair the installtion. You can do this by going to Control Panel >> Add/Remove Programs >> NI Software >> Change >> Select "DAQmx"  >> click "Modify" >> and select "Repair." Please let me know if either of these steps eliminates the problem.
Hal L.
Message 2 of 12
(7,578 Views)
I have done that already, it will work for awhile, but then the problem will come back later after several On and OFF on the machine.
I get this error message under System Event Viewer.
The NI Configuration Manager service terminated unexpectedly. It has done this 1 time(s).
Source: Service Control Manager     Event ID 7034
The nidevldu service terminated unexpectedly. It has done this 1 time(s).
I cannot duplicate the problem if I disconnect the computer from the machine "without" the NI cable connected. It seems this problem can happen when I have the computer connected to the machine.
Johnny
Message 3 of 12
(7,562 Views)
Hi Johnny,
This is a very strange error. What OS do you have on this computer? If it is Windows XP, what service pack(s) do you have?
Hal L.
Message 4 of 12
(7,544 Views)
Windows XP SP2 Professional.
Message 5 of 12
(7,543 Views)
Hi Johnny,
Thanks for the information. Since you have repaired the driver and it didn't fix the issue, I would like you to try a full uninstall/re-install of the driver. Also, just to make sure I'm clear: you are using version 8.0.1. What hardware do you have installed on this system? Please let me know what you find out.
Hal L.
Message 6 of 12
(7,522 Views)
I have done that already, Process to uninstall the driver.
Remove from Add/Remove Programs, reboot the PC.
Go Program Files and delete the National Instrument folder.
Open Regedit, and remove anything related with National Instrument Key/folder.
Reboot the PC again, and then re-install the new 8.01 version.
Hardware installed on the PC: PCI-DIO-32HS
Johnny
Message 7 of 12
(7,521 Views)
Hi Johnny,
If you have already performed these steps, then I think that we have exhausted all of our possiblities here. I recommend contacting National Instruments Technical Support directly for assistance with this issue.
Hal L.
Message 8 of 12
(7,508 Views)
I did, that was my first option.
He told me exactly what you have told me, but as you know we always need to ask for a second opinion, if the issue still pending...
Thanks a lot for your help my friend.
Johnny
Message 9 of 12
(7,507 Views)
Hi Hal and Johnny,
Was this issue ever resolved?  There is a customer experiencing a similiar issue.  Any help would be much appreciated, thanks!
Erik
Message 10 of 12
(7,041 Views)
