08-24-2006 12:16 PM
08-25-2006 09:50 AM
03-01-2015 09:11 PM
Hi, I have this problem as well. I have installed the August 2014 drivers but I still got this error message. Please suggest how I could resolve this. Thank you very much.
03-02-2015 03:19 PM
mariotapilouw,
Since this is a very old thread, I would recommend creating a new thread with the details of your issue in order to increase its visibility.
03-03-2015 02:04 AM
Hi Kirk,
I still haven't found the solution. I'm wondering, what exactly is this file and why I cannot find it anywhere in my computer?
03-03-2015 09:38 AM
Mariotapilouw,
Again, I would recommend making a new thread in order to give your issue more visibility--because of the forum structure (and how NI tags these issues) your issue will be more visible and therefore be more likely to get resolved if you make a new thread.
06-28-2017 06:10 AM
Hi i am facing the same problem. I have installed 2012 NI drivers for DAQ. Win xp OS.
But still i get the error. Is there any way to fix this?
06-28-2017 07:45 PM
I remember I had to install old version of the library to resolve this issue. Which version of Ni DAQMx are you using right now?
06-28-2017 10:25 PM
Hi i have installed the NIDAQ951f2.exe with the following description:
NI-DAQmx 9.5.1 - Windows 7 32-bit/7 64-bit/Vista 32-bit/Vista 64-bit/XP 32-bit/Server 2008 R2 64-bit/Server 2003 R2 32-bit.
You can check this link: http://www.ni.com/download/ni-daqmx-9.5.1/2933/en/
This is the driver recommended for NI PCI-MIO- 16E-4 and Windows XP OS. I cannot migrate to higher version of the driver due to some client project restrictions. How can I fix the issue with the present setup?
11-13-2018 05:00 PM
Hi Did you tried force resintall the driver? https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8U0SAK&l=en-US
