08-26-2011 01:17 PM
I'm trying to get the product number and name of the National Instruments card installed on my computer. According to the manual when I get the property for nxPropDev_Name I should get NI PCI-8512 (2 ports) for an NI PCI-8512 device. Instead I get an empty Cstring. For nxPropDev_ProductNum I should get 8512 for an NI PCI-8512 device, but instead I get this number: 3435973836. Below is a snippet of the code I'm using. Is there something I am doing incorrectly? Thanks int propSize; int cpropSize; u32 propName; CString cpropName; char *l_pSelectedInterface = "CAN2"; char *l_pFrameArray = NULL; char *l_pSelectedDatabase = ":memory:"; char *l_pSelectedCluster = ""; g_nxStatus = (*m_pNxCreateSession)(l_pSelectedDatabase, l_pSelectedCluster, l_pFrameArray,l_pSelectedInterface, nxMode_FrameInStream, &SessionRef); g_nxStatus = (*m_pNxGetPropertySize)(SessionRef, nxPropDev_ProductNum, (u32)(&propSize)); g_nxStatus = (*m_pNxGetProperty)(SessionRef, nxPropDev_ProductNum, (u32)(propSize), &propName); g_nxStatus = (*m_pNxGetPropertySize)(SessionRef, nxPropDev_Name, (u32)(&cpropSize)); g_nxStatus = (*m_pNxGetProperty)(SessionRef, nxPropDev_Name, (u32)(cpropSize),
08-29-2011 02:50 PM
Hi Carbert,
I know you're using visual studios so this forum could be applicable, but I believe you would get more help if you posted this question in the Automotive and Embedded Networks forum. There you will find a much deeper pool of expertise in XNET programming as well as quite a few VB programmers, and it will allow us to keep the forums organized for those looking for similar answers later.
Thanks!
Peter W.
