Measurement Studio for VC++
Generating Finite pulse train at specific positions.
I have an application that needs to output a trigger signal at very specific position.
There is n triggers to be generated in this fashion :
Y axis ------>
0                  1     2     3     4     5...n-1  n
0: Start Position
1...n : positions of triggers to be generated.
Physical distance between triggers is fixed and known.
Here's my current implementation
    errCode = DAQmxCreateCOPulseChanTicks(m_3DTriggerTask,
                                          TRIGGER_3D_COUNTER,
                                          ENCODER_Y_PIN_A,
                                          DAQmx_Val_Low,
                                          disToStartCnt,
                                          highPulses,
                                          lowPulses);
    if (DAQmxFailed(errCode))
        Log << err << CURRENT_FUNCTION << " Can't create 3D trigger output channel. Error " << errCode << endl;
    errCode = DAQmxCfgImplicitTiming(m_3DTriggerTask, DAQmx_Val_FiniteSamps, nProfHw);
        Log << err << CURRENT_FUNCTION << " Can't set continuous mode for clock. Error " << errCode << endl;
The issue arise when not moving, there is a lot of noise on the line ENCODER_Y_PIN_A since its a single phase of my encoder.
I'm wondering if someone knows an example code ( I have been looking but couldn't find) or could point me to a direction to fix this issue.
Thank you
Message 1 of 1
(1,637 Views)
