Measurement Studio for VC++
Device identifier is invalid: USB-6356 (32 MS) on Ubuntu 20.04.4 LTS
I have problems finding my device (USB-6356 (32 MS)) on Ubuntu 20.04.4 LTS (GNU/Linux 5.4.0-122-generic x86_64).
I am using #include <NIDAQmx.h> which is successfully installed. Howevere trying to determine the device name and runing a self test gives ERROR -200220
$lsusb
Bus 005 Device 002: ID 3923:7561 National Instruments Corp. USB-6356 (32 MS)
$nidaqmxconfig --self-test Dev2
Failed
Error -200220
Device identifier is invalid.
Device Specified: Dev2
$nilsdev
 no result.
Any ideas will be greatly appreciated. Thanks!
(2,077 Views)
The Bus 005 Device 002 is a PCI enumeration naming. You will first have to configure a NI-DAQmx configuration that assigns an alias to all detected hardware. Under Windows this is done with NI-MAX but under Linux you need to run the nidaqmxconfig utility as pointed out in this page.
Rolf Kalbermatter
My Blog
(1,925 Views)
no. USB devices are not supported. nothing to do.
(492 Views)
Yep you are right. Just checked on the NI Hardware and Software Operating System compatibility
page and there is of course clearly visible that these devices are not supported under Linux unlike the same models for PCIe and PXIe.
Rolf Kalbermatter
My Blog
(472 Views)
