Hello?
I'm testing this code whether DAQmx finds my legacy PCI-6025E device.
DAQmxErrChk code doesn't work for me.
My code is
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int CTestDialogClass::FindMyDAQLegacyDevice_With_DAQmx()
int32 error=0;
char errBuff[2048]={'\0'};
char devNames[256]={'\0'};
char testDevName[256]={'\0'};
// DAQmx Configure Code
/* It seems that DAQmxGetDevProductType and
* DAQmxGetSysDevNames function works w/o
* creating a task.
/* DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxStartTask(taskHandle));
DAQmxErrChk (DAQmxGetDevProductType("Dev1", testDevName, 256));
DAQmxErrChk (DAQmxGetSysDevNames(devNames,256));
// DAQmxGetDevProductType("Dev1", testDevName, 256);
// DAQmxGetSysDevNames(devNames,256);
// DAQmx Start Code
m_cstringProductName = testDevName;
m_cstringDeviceName = devNames;
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
AfxMessageBox("DAQmx Error, DAQmx can't find the device", MB_OK,0);
/* if( taskHandle!= 0 ) {
DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
return 0;
As you see, I commented out some code to find which line makes an error. Even if I don't use DAQmxErrChk function and DAQmxCreateTask, the GetDevProductType and the DAQmxGetSysDevNames functions STILL works.
I wonder why the GetDevProductType and the DAQmxGetSysDevNames functions are working WITHOUT
I'm converting DAQ to DAQmx..from Parkoz.com
