Measurement Studio for VC++
DAQmx compatibility with MSVC 2015 compiler
Dear all,
I'm trying to realize a software in Cpp using the compiler MSVC 2015 64bit. But apparently the Nidaq.lib provided with my NI pcie card was compiled by a 32bit compiler (probably gcc since my testing software works properly when I use Mingw 32bits). is there another lib compiled for 64 bits compilers somewhere?
thanks in advance for you help
(2,732 Views)
just in case someone needs the same library, it's located in :
<Program Files (x86)>\National Instruments\NI-DAQ\DAQmx ANSI C Dev\lib\msvc
(2,705 Views)
Hi Olivier,
Yes there is a NIDAQmx.lib for 64 bits compilers and it is located in the following folder : C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc.
Bertrand
(2,684 Views)
