Measurement Studio for VC++
Reply
DAQmx compatibility with MSVC 2015 compiler
Dear all,
I'm trying to realize a software in Cpp using the compiler MSVC 2015 64bit. But apparently the Nidaq.lib provided with my NI pcie card was compiled by a 32bit compiler (probably gcc since my testing software works properly when I use Mingw 32bits). is there another lib compiled for 64 bits compilers somewhere?
thanks in advance for you help
(759 Views)
Highlighted
Re: DAQmx compatibility with MSVC 2015 compiler
just in case someone needs the same library, it's located in :
<Program Files (x86)>\National Instruments\NI-DAQ\DAQmx ANSI C Dev\lib\msvc
(732 Views)
Hi Olivier,
Yes there is a NIDAQmx.lib for 64 bits compilers and it is located in the following folder : C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc.
Bertrand
(711 Views)
