04-02-2012 12:40 PM
I`m having problem with one DLL file generated by labview. I got dll file, with .h file and .lib file, but I actually dont know how to call function from labview dll file.
Here is structure of functions, and code I tried to call.
[code]
TD1 *xRefPtr = new TD1;
TD1 *yRefPtr = new TD1;
TD7 *xPointsPtr = new TD7;
TD7 *yInterpolationPtr = new TD7;
TD1Hdl xRef = &xRefPtr;
TD1Hdl yRef = &yRefPtr;
TD7Hdl xPoints = &xPointsPtr;
int32_t Type;
TD7Hdl yInterpolation = &yInterpolationPtr;
(*xRef)->dimSize = 1;
(*xRef)->elt[0] = 1.185739365;
(*yRef)->dimSize = 1;
(*yRef)->elt[0] = 0.137887336;
(*xPoints)->dimSize = 1;
(*xPoints)->YValue[0] = 1.195739365;
//Should I do something with yInterpolation?????
//(*yInterpolation)->dimSize = 1;
//(*yInterpolation)->YValue[0] = 102545.11;
CalcInterpolation2D(&xRef, &yRef, &xPoints, 3, &yInterpolation);
[/code]
And function CalcInterpolation2D is declared as:
CalcInterpolation2D(TD1Hdl *xRef, TD1Hdl *yRef,
TD7Hdl *xPoints, int32_t Type, TD7Hdl *yInterpolation);
04-03-2012 02:44 AM
Hi Raaj,
- which LabVIEW version did you use to make the DLL?
- from which environment are you trying to access the DLL?
- what problem do you get from your current code? Which error messages?
- what are your TD1, TD7 and TD1Hdl and TD7Hdl datatypes? How are they defined?
Joseph
04-03-2012 04:16 PM
Hello Joseph,
Thx for the reply.
- I am not sure which version was used. I was given only the header file and the dll. But I guess dll was made using the LabView 2011.
- I am trying to access the dll from the VC++ environment
- I would like to know the definition of the function and definition of the parameters in the function, which is present in the header file of the dll.
- TD1, TD7 and TD1Hdl and TD7Hdl datatypes are defined using the labview environment.
For example,
typedef struct {
int32_t dimSize;
double elt[1];
} TD1;
typedef TD1 **TD1Hdl;
Plz lemme knw if I have to give more info.
It will be helpful for me if you please tell me whether I can use any utility tools in order to see the definition of the function and it's parameters in the header file. (I heard abt DEPENDENCY WALKER).
04-04-2012 01:54 AM
Hi Raaj,
I cannot tell you much about the meaning of the different parameters since that depends on what was programmed.
In order to use a DLL created with LabVIEW you need to make sure the LabVIEW run-time engine for the relevant LabVIEW version is installed.
It is important that the run-time engine is installed in the same version as the LabVIEW version used to create the DLL so you need to find that out from the developer of the DLL.
I take it that the datatype in LabVIEW is a cluster, which is what naturally maps to a struct in C, but I cannot say any more than that.
What problem are you having when trying to use functions from the DLL? Do they return an error? Does the program compile at all? I don't yet undestand what your question is.
Joseph
