Modular Data Acquisition
High-Performance Test
06-21-2012 03:29 AM
HI,
How to set the CWGraph color map using command line? I managed to set the color map using the CWGraph properties tab. However, if i use multi scheme color map, i need to code the color map using the command line. Any simple example?
thanks!
