The operator just converts a value to a string and appends the string representation to the end of the string. It only supports a subset of data types, namely characters, integers, shorts, longs, floats, doubles, and strings. None of these data types should cause errors. What kind of errors are you seeing or anticipating?
The string is being loaded from a file, then I am converting the string to doubles. I just want to put in some kind of error checking in case the file contains some junk. "1.23 2.47 3garbage.34 5.25" e.g.
Sorry, I should have read your question more carefully. I was talking about operator<<, but you were asking about operator>>. CNiString::operator>> does not throw exceptions if the data's in the wrong format.
