Good morning,
I wrote a command line app using ANSI C header and lib files ( NIDAQmx.h and NIDAQmx.lib ). I am trying to deplying it but when I try to run it I get crash due to some missing dll.
Running dependendy walker on the *.exe and searching a bit in the NI posts seems that I need the nicaiu.dll so I manually copied it from system32 to the binary level but I still get the crash when trying to run it. So I ran dependency walker again but this time on the nicaiu.dll and seems that the dll need the nispylog.dll that I don't have in my system.
I would have a help on this, I need to know which dlls do I need to deploy my ansi c command line applications and I also need those dlls please.
I compiled my app with VS2012 ( I don't use dot net, only ansi c ). The VS dependencies are there.
Thank you
Franco
