This can be done for analog input by acquiring in continuous mode at 100Hz (of course, aggregate not simultaneous), but for analog output, 600x supports up to 150S/s analog output rate with software time. Hence, its timing totally depends on how fast your PC run and it's not going to be precised. Hence, you need to change to USB-62xx or USB-63xx that supports hardware time analog output.
