Measurement Studio for VB6
problem redistributing the cwui.ocx
Hello everybody,
I have a problem redistributing the cwui.ocx
from Measurement Studio 1.00.
I have created a Install-Shield-Script (InstallShield for Visual C++ 6.0)
and added all the MFC and OLE Stuff as described in the
Component Works help- file.
This works fine on nearly every computer.
We have one Box with Windows NT 4.0 SP 5 where it is not possible
to registrate the cwui.ocx .
I am sure that the all the needed dlls are the correct version.
Even if I try to register the cwui.ocx with the regsvr32.exe it does not
work.
Does anybody know if there are any other files needed which are not
listed in the CW- Help- File ?
Does anybody have other suggestions ?
Thank You
By Oliver
(3,572 Views)
"Oliver Bauer" wrote:
>>Hello everybody,>>I have a problem redistributing the cwui.ocx >from Measurement
Studio 1.00.>>I have created a Install-Shield-Script (InstallShield for Visual
C++ 6.0)>and added all the MFC and OLE Stuff as described in the>Component
Works help- file.>>This works fine on nearly every computer.>>We have one
Box with Windows NT 4.0 SP 5 where it is not possible>to registrate the cwui.ocx
.>>I am sure that the all the needed dlls are the correct version.>Even if
I try to register the cwui.ocx with the regsvr32.exe it does not>work.>>Does
anybody know if there are any other files needed which are not> listed in
the CW- Help- File ?>>Does anybody have other suggestions ?>>Thank You>>By
Oliver>
What error message do you get whe
n you try regsvr32? Try running Depends
(Visual C++ Tools) with cwui.ocx on the machine to see which DLLs are missing.
(3,572 Views)
