Hi All,
I am not sure where else to put my question.
I am using Measurement & Automation Explorer v 4.5. I have a set of data but one or two tags have blanks in between recording.
When i say blanks, other tags would show lines but not these 2 channels. It is just as if there is no data.
further info on these channels are these 2 are type of memory in the tag file. So this is actually an output of calculation (y=x * 0.5 this is the formula literally). other tag that is type of memory and also a calculation result do not exhibit the same behaviour.
Would anyone have an idea what is that i am facing?
Thank you
Asadilan
